跳转到主内容
雪佛兰科鲁兹是通用汽车公司雪佛兰分部生产的一款紧凑型轿车。科鲁兹于 2008 年首次发布,采用前置发动机、前轮驱动设计。
Why is my car not starting and showing code 89
My 2012 chevrolet cruze is giving problem to start as if my battery if flat bt all the lights and hooter are working properly.When i turn the key the alternator turns a little bit and gives me code 89.When i jump start the car it starts without any problem.my battery was serviced and the car could start atleast 4 times after that but then it started with the problem the next day
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
I also have similar problem.
Error code 89, sound is loud.
What could be the problem?
完成的
Yes, similar the noice of the engine become in side the sound system...through the speakers.
完成的
添加一条评论
2个答案
最有帮助的答案
Hi,
Check the output from the alternator.
Use a DMM (Digital Multimeter _ Voltmeter function) and connect it across the battery terminals with the engine running, (Be careful when you do this as the engine is running!)
The Voltmeter should read between 13.8-14.4V DC. If it is less than 13.8V DC then the alternator is not charging the battery and it will slowly go flat.
If this is the case take your car to an auto electrician to get the alternator checked.
这个答案有帮助吗?
得分 2
添加一条评论
This some how related to the steeeing lock, shutdown the car and press the start button without break (or open the contact if its not with a keyless start) and then unlock the steering then move a lttle left or right the start the car it will start normaly.. If it works dont ask me why coz I dont know, I just discover this solution by myself
这个答案有帮助吗?
得分 1
1条评论:
Thermostat issues
完成的
添加一条评论
添加你的答案
Joseph cafu 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 43
总计 47,052
