跳转到主内容
加入维修社区 - 创建账户
The Toshiba Satellite C55-C5268 is a general use laptop designed to be used with windows 10. It was manufactured by Toshiba in 2015.
Why won't my mouse buttons work?
The two mouse buttons on my laptop aren't jammed but when I click on something it doesn't respond. The touch pad above the mouse works fine and I can click on things with that but the mouse buttons still don't work. What is causing this problem and how can I solve it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
There are a couple of reasons you might be having this problem.
First, make sure your laptop does not have a "disable mouse button" command. This feature can usually be turned on and off by pressing Fn+(F1,F2,F3, etc). If you still have the user manual you can check that for the specific command.
Another reason is a bit more intensive to check. The ribbon cable connecting the touchpad buttons to the motherboard might be disconnected, which would require you to remove the bottom cover of the laptop to reinsert. Removing the bottom plate is fairly easy, just follow the guide here. The cable you'd be looking for would be coming out of the back of the touchpad and leading to the motherboard.
The buttons themselves could also be faulty. This could happen over time through use, or if something got spilled on them. In this case your best option would be to replace or clean them.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ben Rounseville 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 681
