跳转到主内容
Phone stuck in a boot loop
The other night my phone did an update and when I woke up the next day it was on the Huawei logo that appears when booting the phone up, I took out the battery after 10 minutes of it staying on the logo and turned it back on and the same thing happened again, I have entered recovery mode and done a factory reset and wiped the cache partition, I cannot find a download for the right firmware. Any help would be greatly appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Same here mines stuck on logo screen will not turn on tried everything
完成的
添加一条评论
2个答案
Use a small paper clip in and in the back of the tab is a small button by the headphone jack and quickly click it with the paper clip then turn it back on
这个答案有帮助吗?
得分 0
1条评论:
Thank you, I found the hole and placed a paper clip in it and pushed but it didn't click or move at all, If you have any other tips they would be much appreciated
完成的
添加一条评论
follow instruction here
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
andrews122 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 16
总计 10,814
