跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Tabs are Samsung's flagship tablets that compete with iPads.
Why Isn't my tablet turning on?
Okay, so this morning I dropped my tablet, while getting out of my car and it fell on the ground and cracked slightly. I could still use it, however. The touch ability worked and everything worked as normal, just that it had a crack at the corner and across it. So then later this evening it suddenly turned off?? Like it wont even respond when I put it for charge or touch the home screen button??
Also, I don't know if this is going to be helpful, but a few minutes before the tablet turned off I had put it on top of the laundry basket. The clothes weren't really that wet, but I don't know if somehow the screen is extremely sensitive to water and it seeped through the cracks and damaged the tablet further or something??
Please respond!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
i think i would like you to charge your tablet for 30 min and make sure you see the charge is coming to tablet .
than press the power key and hold for like 40-50 sec and wait see if this turn on . t think charger socket may be broken . try opening the tablet using ifixit tools and see if you check the charger socket .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dangerousdream29 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 117
