跳转到主内容
Model 1211 maximum RAM
What is the maximum RAM for Model 1211 ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Check here
这个答案有帮助吗?
得分 3
1条评论:
Apple's RAM recommendations are based on chips available at the time, and are often not accurate. Better to check using the free MacTracker program, on everymac.com, or using something like Other World's configurator at http://eshop.macsales.com/MyOWC/index.cf...
完成的
添加一条评论
you can install 4GB (2 x 2GB modules) in this model MacBook Pro (aka Late-2006 series MacBook Pro), but only ~3GB will be recognized and used by the system.
this is because part of the 4GB memory space is reserved & used by certain system functions. I have this particular model 2.33GHz 15" MBP with 2x2GB installed and can verify this is true.
这个答案有帮助吗?
得分 2
1条评论:
In which case he would want 1x2GB+1x1GB
完成的
添加一条评论
I have a late 2006 model A1211 2.16GHz intel core 2 duo running lion and 4gb of ram I have two 2gb cards in it works great!
这个答案有帮助吗?
得分 0
添加一条评论
Ignote Bac's follow up answer.
Just because the system dosn't show up doesn't mean it's not being utilized.
Use 2x2gb in order to use dual channel mode correctly in a ddr2 system like this, otherwise his 3gb suggestion will run much slower.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raymond 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 8,522
