Replacement screens not working
Customer has a broken screen, I replace the screen and get a black screen, check connections all good so I try another replacement screen still black screen. I had replaced a 5s screen earlier that day so I decided to try it on this phone as I know it works and the damaged screen works. So I try the other screens again and they still don't work.
Thinking that I just received 2 faulty screens I order in 2 more screens and received 2 replacement screens and I test them on this unit and nothing however when I install the damaged screen it works.
Has anyone had this issue or have any ideas?
3条评论
where did you order the screens from?
I've had whole (100+) batches of screens be bad. Its not common but its not uncommon either. But its for sure maddening when it happens.
由 Josh W 完成的
When I install the broken screen assembly from a phone interview had replaced earlier everything is working including the backlight. It doesn't make sense that the new replacement screens don't work with this device however a broken screen assembly works.
由 John Green 完成的
Disconnect and reconnect the battery.....
由 Oliver Liriano 完成的
