跳转到主内容
加入维修社区 - 创建账户
The Nokia Lumia 830 is an economical smartphone developed by Microsoft Mobile.
Why can't I hear any sound when I make calls?
When I make calls the phone shows that I am calling someone, but I can't hear anything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
If you can’t hear any sound during a call, try turning up the volume setting using the power button on the side of the phone. If that doesn’t work, it’s probably a mechanical problem. See our repair guidefor replacing the earpiece speaker on a Nokia Lumia 830.
这个答案有帮助吗?
得分 0
添加一条评论
Before you trying repairing anything, take a look at the earpiece speaker at the top of the screen. Sometimes oil and dead skin can build up a small layer covering up the speaker grate. Try taking a Q-Tip [preferably dipped in an strong alcohol solution] and cleaning the grate. Try not to press too hard, but that might help. If not, then I'd follow Adam's advise and replace the speaker.
这个答案有帮助吗?
得分 0
添加一条评论
Sometimes it related with coverage, do you have good reception of gsm signals? Have also tried another sim? Maybe the number you tried to call isn't there anymore?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Schmitt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 7,120
