跳转到主内容
The Creative Nomad Jukebox Zen was a portable music player from the early 2000's. Its main claim to fame was its ability to hold a lot of music.
Why is my device not powering on?
I tried pressing the power button and the device does nothing. The device is plugged in.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
I bought a new battery for mine it played for about 10 mins , so I could check it was charging, when I turned it on again I got nothing.
完成的
添加一条评论
2个答案
If the device is plugged in and still is not turning on, it may not actually be charging the battery. First try plugging the device into a different outlet in your home to ensure it is either the device or the charger. If it still not charging, you may have to purchase a new charger. If the device is still not powering on the charging port on the device could be damaged. This will need to be replaced. If nothing else has fixed the issue, the battery is your last option. Replace the battery and the device should work correctly.
这个答案有帮助吗?
得分 0
添加一条评论
I have the Nomrd jukebox Zen I believe it's the first one to come out it's not a Xtra or any other type just the jukebox Zen what's is it worth,how does it work please send a video for me to watch?? Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William Meyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,366
