跳转到主内容
发售于2014年春季 的一加 一拥有着5.5英寸的显示屏 运行着基于Android的CyanogenMod 12S操作系统。
110 个问题 查看全部
Black screen but can feel the touch
hello , I've dropped my oneplus one on the floor at a bar , so the screen got broken and a lit bit of alcohol went inside , i changed the screen and then everything was good except when i got a message or any notification while my telephone is locked , it stays black ... i still can use it but without seeing anything . if i reboot my telephone (forced reboot ) i can see everything again till i lock and receive a notfication .... please someone got the same problem or now a solution for this ? thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Worst case the liquid has damage the logicboard and that's why the screen goes black in some situations, you could always try to redo the guide for changing the screen sometimes a cable has not been attached properly.
Also take a look at the OnePlus forum might bee that someone has already had that situation.
https://forums.oneplus.net/forums/the-on...
这个答案有帮助吗?
得分 1
添加一条评论
i did many times... i think it's the logicboard that has been damaged.
thank you for your answer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
saad 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 2,571
