跳转到主内容
How to upgrade the M.2 SSD
Dear ifixit team,
I have an HP Spectre X2 Detacheable 12 inch tablet. However, the unit comes with a 128GB M.2 2280 ssd. Does anybody know on how to open the unit in order to replace this ssd with a larger capacity? Thank you so much for your answers. Regards Surfix007
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
3个答案
最有帮助的答案
Here is the "end of life" recycling guide that shows some basics on how to take the spectre x2 apart. Would be a good place to start on a project like replacing the SSD.
http://h22235.www2.hp.com/hpinfo/globalc...
这个答案有帮助吗?
得分 2
2条评论:
I have HP Spectre X2 12-a009nr. Theres no 4 screws like in the link that you provided :(
完成的
I think you need to follow this guide: http://h22235.www2.hp.com/hpinfo/globalc... . If so then I won't touch it as it is glued together.
If, however, you have found a solution please let me know as I would also be interested to know
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
you can open the machine without removing the screen from the bezel.. use a spudger between the black plastic bezel and metal frame. It will pop off easily, and reinstall with no glue. I take mine apart for fun. the drive is a standard m.2 sata ssd
这个答案有帮助吗?
得分 0
1条评论:
Start in the upper right corner near the power button.
完成的
添加一条评论
添加你的答案
Rainer Michelis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 2,319
