跳转到主内容
The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
47 个问题 查看全部
Bose Soundlink Color charges but does not turn on!
Hi,
For some reason my Bose Soundlink Color charges fine and is now fully charged as it quickly flashes the green light when you plug it out, however, it DOES NOT turn on.
I've tried the Bose Updater, but I don't think it even recognizes my device as it doesn't do anything. It worked fine about 4 days ago so I don't know what happened and why it's not turning on.
I've tried the 15 second play/pause button, I've tried doing Factory reset... and it can't be my battery since it's fully charged?
Somebody please help me!
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
11条评论
Hi, Does it turn on when you have the charger connected and switched on?
完成的
@jayeff The charger is connected and the speaker is fully charged as it's showing the green battery light. However, it does not turn on. Very sad...
完成的
Me too same problem
完成的
When i tried to charge it .it shows the green light and after 3 second the green light disappear and it wont turn on even in charging
完成的
I've exactly the same problems. Anybody got solution to this problem? Is the battery run out?? Anybody tried Bose customer care center?
完成的
显示更多的6条评论
添加一条评论
3个答案
已选择的解决方案
Hi,
If the speaker is out of warranty and as as you have tried a factory reset which hasn't worked, my only suggestion now is that you try a power 'reset' and see if this will resolve the problem.
To do this you will have to open the speaker and disconnect the battery. This will require you having soldering skills and tools. Once you have disconnected the battery, press and hold the power button for 20 seconds to dissipate any residual charge in the device and then release the button.
Once this is done reconnect the battery (be careful to reconnect the wires to their correct connection points) and try turning on the speaker and see if it has been restored to normal operation.
Here is the relevant Ifixit guide to remove the batteries in your speaker.
Bose SoundLink Color Battery Replacement
这个答案有帮助吗?
得分 3
3条评论:
Thank you for your help
完成的
Did this help in your case? Before I open up my bose, I'd like to know if it resulted in anything.
完成的
What size are the Torx security screws. Thank you
完成的
添加一条评论
Connect to the computer. If you hear the chirp that a USB device is connected, but it still wont turn on or work, try to update the firmware at the Bose Official Update site:
http://btu.bose.com
这个答案有帮助吗?
得分 1
添加一条评论
I did have the same problem, here’s what I did.
  1. used original cable and charger
  2. got the amber power light to flash
  3. did the “press Play/Pause for 15s; disconnect power” reset.
  4. turned unit back on, and immediately did a factory reset by holding aux & - buttons together
  5. paired my Bluetooth device again
  6. it has been playing for half an hour now, but cannot turn off the unit or switch sources. It is basically frozen in the ON/Playing state.
I’ll need to go through the above steps to use it every time.
这个答案有帮助吗?
得分 0
1条评论:
Hi, regarding the step 4. AUX + all buttons? or AUX + Play/pause button only? THanks.
完成的
添加一条评论
添加你的答案
Zoe Farah C 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 64
总计 18,617
