跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Is this motherboard fried?
Hello there could anyone tell me if my motherboard is fried?
It looks like black stuff has dripped onto some circuits at the side of the processor.
I got the phone water damaged then cleaned it out with 100% alcohol done the same to the charger port ect all the connectors for the screen battery ect.
The phone powered up fine after that was doing everything it should then just cut out.
https://postimg.org/image/yrbtdlke7/
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
As Earl said, that is underfill. It's used to solidly hold delicate IC's to the circuit board and prevent water from getting underneath. It's not perfect but a very good solution for manufacturers. It's a pain to work on though for repairers.
The connector on the upper left appears to be damaged. Do you have continuity between the pins on the inside of the connector and the pcb pad upon which those pins are soldered. Sometimes the corrosion eats away at the solder joint. Otherwise, water damage can be very insidious, eating away underneath IC's.
You only show one side of the board. What does the other side look like?
Water damage is the hardest thing to troubleshoot because you don't know where all the damage is. What you see can sometimes be the tip of the iceberg. Focus on the connector for now. If you have a very fine point soldering iron and some experience, you could try and touch up those connections if needed. Only if needed...you can do more damage than good if you slip even only a few millimetres.
Otherwise, I suggest you find a repair shop that specializes in water damage and micro-soldering. The phone is not too old so you need to determine if a repair is worthwhile. Certainly if you need to recover data.
这个答案有帮助吗?
得分 2
添加一条评论
that's probably underfill
这个答案有帮助吗?
得分 1
2条评论:
What does this mean and can it be repaired?
完成的
and get bga x rays too
完成的
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 594
