跳转到主内容
加入维修社区 - 创建账户
Middle Row of Keyboard Stopped Working
The middle row on my keyboard stopped working. Not sure if my daughter spilled something on it. How can I fix this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Ouch! not good ;-{
If you haven't worked on these systems before you should think about bring it into an Apple Store and letting them replace the upper case. Hopefully, its nothing more than the keyboard that got hit.
If you are up to giving it a try here is the IFIXIT guide: MacBook Air 13" Early 2014 Upper Case Replacement. Now with the winter coming on make sure you follow good ESD practices and use an antistatic mat and wrist strap as you'll need to take the logic board fully out.
Some people do manage to take the keyboard fully out after they remove the uppercase to try to clean it. Frankly, it's a lot of work and often the results are not as good as just replacing the keyboard which you could do here as well if you've done it a few times. Still a lot of work which is why for a DIY project I recommend just replacing the uppercase assembly.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
josh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 3,175
