跳转到主内容
加入维修社区 - 创建账户
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
adhesive won't stick on new cable
I bought new volume cable but can't get the adhesive to stick. Any Advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Replace the existing adhesive on the housing or volume button cable itself with new adhesive?
I know that Tesa / Red transparent double sided tape works well for this.
完成的
添加一条评论
2个答案
已选择的解决方案
It kind of depends on what part of the cable. For most of it, red tape is fine. The part that always gives me problems is where it goes from volume to power and is on top of the frame. I use yellow tape for that part. If the volume buttons are giving you trouble, cut out tiny little pieces of red tape.
I'm pretty sure all of those volume flexes were made when Reagan was in office. The adhesive is always messed up on them when I go to use them.
这个答案有帮助吗?
得分 2
添加一条评论
Yes the tesa tape would work with this repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon Ballington 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 213
