跳转到主内容
这是iPad mini 3(型号A1599)Wi-Fi版本的维修指南。这款iPad在2014年10月6号作为iPad Mini Retina屏版本(现在也做iPad mini 2)的新一代被发布。
The screen rotates the wrong way
Hi, the screen of my iPad mini 3 rotates the wrong way, exactly, when the ipad is in vertical position the screen rotates in horizontal position and viceversa. I have already reset my ipad to the factory settings but with no results. Is there any solution for this defect? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
That's a strange problem did you try to lock the screen? While on the home screen Swipe up from the bottom from the screen which will display some options, the lock icon is at the top of this option box and has a lock with a circle around it. See if that helps!
这个答案有帮助吗?
得分 0
添加一条评论
hello, I have already tried to block the rotation of the screen, but this only locks the screen in a certain position, however, I would like to eliminate the problem permanently.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
adinmoldova 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 1,892
