跳转到主内容
Repair guides and support for Fujifilm's FinePix line of cameras.
160 个问题 查看全部
Display warning: Turn off camera and turn on again
I have a Fujifilm FinePix Camera L55 and due to USB broken, I replaced the motherboard, afterward the camera get on normally after charging. with display indicating battery charging, etc. But after trying to setup camera, at a moment the display show this message "! TURN OFF THE CAMERA AND TURN ON AGAIN" After followed up the display instruction for about 3 to 4 times. the problem still there,
Could you indicate if I failed on reassemble or any help please,
Regards and thanks
Louis
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
it is saying turn off and turn on again but nothing is happening
这个答案有帮助吗?
得分 1
1条评论:
I have turned it off and on again and nothing is happening
完成的
添加一条评论
Hi, thanks for response, Yes, nothing happened, the display stay on this warning: TURN OFF CAMERA AND TURN ON AGAIN...and repeatedly the same warning each time..Regards
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Louis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 451
