跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
My iPhone 4 just died. How do I fix it?
So my Iphone 4 was on low battery and i decided to charge it. Every charger i tried, official apple chargers and unofficial chargers, came up with "This accessory may not be supported. Eventually the battery died and i put it on charge and it said it was charging.
Even after waiting a couple of hours, it still showed the dead battery symbol. I put it on over night and yet when i woke up the battery was still dead as it showed the dead battery sign. I plugged it into iTunes yet iTunes doesn't recognize it.
I tried doing a reset but my home button doesn't work so thats not possible. I tried plugging it into my computer for an hour but still it says the battery is dead. I then opened it up, disconnected and connected the battery and... nothing.
Well now the phone shows only a black screen, isn't recognized by iTunes and no matter how much i charge it, doesn't seem to turn on or work, even when i press the power button or hold it down. Any help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
seems like your 30 pin dock connector is shot. Buy a new one from ifixit, and buy a new water sensor to put in it so dust doesn't enter the water sensor hole (tell apple your doing this, if the old sensor is red when viewed from the outside), and then reinstall it. stick in the new water sensor, red side facing inwards, white facing outwards, and TADA. phone works again. view the ifixit guide for iphone 4 dock replacement.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
No Thanks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 130
