跳转到主内容
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
61 个问题 查看全部
The touch screen does not work on iPad Mini 2 LTE
The touch screen does not work, I have changed the glass and it has stopped working the following week.
Perform the change of touch glass by a fall. The glass broke. I made the switch and the tablet worked perfectly for one week. But one nigth after loading it ... the tablet stopped working the next morning.
The first option is a reboot ... it did not work. The iPad's touchpad did not work after restart.
I have to add that I replaced a new glass to rule out that it was not crystal failure. I think the error may come from the motherboard.
I took all precautions for repair. I disconnect the battery and all the terminals following the indications of ifixit.
The iPad, It ran for a week perfectly, but stopped working the touchpad. The iPad turns on and can connect to iTunes, but I need the touchpad to unlock it.
Can anybody help me? Anyone have a previous solution?
Thank you so much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
完成的
添加一条评论
2个答案
最有帮助的答案
Have you tried a restarted? If you have not try this: Simultaneously hold down the start button, in the landscape position middle of the right hand side, and the off button, upper left hand edge. Hold for fifteen seconds. The screen will go dark and then a white Apple with a bite out of it will appear on a black screen. It may take a few minutes, then the start screen appears. Sign in and see if all systems are working as they should.
这个答案有帮助吗?
得分 1
1条评论:
Yes, the first option is a reboot ... it did not work. The iPad's touchpad did not work after restart.
完成的
添加一条评论
this is probably the touch ic chip. BGA soldered, not replaceable by you or me. take it to a BGA repair service.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Enrique 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,221
