跳转到主内容
Released August, 2010. Identified by part number: 884354009250.
I need some Button Turn off/on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论:
I have the same problem, the button fell out. I have the button but there seems to be something else that is missing because the button doesn't work. when placed back, it's loose. Did you fix it?
完成的
I also have this problem. Anyone?
完成的
添加一条评论
1个答案
Sometimes my H1 loses the date and time. When it does that, it will not record. The unit turns on but pushing the record button does nothing.
I turn it off, hold down the Record button while powering the unit back on. It then defaults to the date. Use the forward or backword buttons to get to the correct date or time. Use the Play button to set the time after you choose the correct time.
Every time I reset the date and time it makes the Record button work. Try it and answer back.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cio Fadhilah 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 1,178
