跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Dirty Contacts causing problems
I took apart my iphone 5 to clean the power button, upon putting it back together I think some cat dander got in the contacts of the internal connections. Tried blowing them off with compressed air, drying it out for a day. many things wont work, like phone wont ring, camera wont work right, etc. Whats the best way to clean the connectors? Is there a brush I can get?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
just use a toothbrush for cleaning. Soft head.
完成的
添加一条评论
1个答案
已选择的解决方案
In cleaning contacts or logic boards I use IP alcohol at 90+% mix and a soft tooth brush . You mentioned using compressed air . Is this from a can or from an air compressor. if its from an air compressor you may have put moisture into the contact inadvertently as compressors tend to pull moisture from the air then blow it out . Using the IP alcohol will help with any corrosion and moisture accumulated on the contact . also check the contact for broken prongs . Use a magnifying glass to inspect it. Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Evan Caulfield 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 54
