跳转到主内容
The first generation Honda CRV, produced from 1995 to 2001.
97 个问题 查看全部
2001 Honda CRV cranks but no start...intermittently!
2 months ago it died right after starting the car before I even had time to put it in gear. I just restarted the car and off I went. 2 weeks later exact same thing....thought water in gas changed fuel filter good to go for a week. Now the last 2 weeks I have been continually stranded everywhere as it seemed fine to start in morning after sitting all nite I run to store come out cranks no start. Wait 20 min. It fires right up! But this week increasingly worse, not starting after sitting a day then all of a sudden fires up I go drive and this last 2 times Im actually cruising about 40 miles down road no sounds just died thank goodness I am able to coast to side park it and begin to walk home. BF took it to AutoZone last week and tried to get codes but it gives nothing. Bf checked spark plug and said weak orange spark. Then 10 min. Later it starts. He says fuel is in the plug and I can hear the fuel pump run when turning key initially. I'm so tired of this. Bought car 2 years ago used and its been perfect. Regular maintenance done oil change etc. Over 200,000 miles on her. Any ideas of which way to troubleshoot? Thank you in advance for Any help. Liz
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
change the coil
完成的
I had a problem like that I changes plugs wires rotor n cap checked the fuel pump all good I was getting spark BUT!!!! the spark was very small the color was white - orange if I layed the plugs on top of head over the hole to each cylinder it shot flames so I figured it was good NOT SO!!! when I put the plugs in nothing !!!! took them out they were wet!!! It ended up being the COIL!!!!! even tho I was getting spark IT WAS NOT A BLUE SPARK replaced the coil hit the key stared up ran rough till it cleared all the excess fuel now it purrs like a kitten !! BE advised unless the spark is blue CHANGE the freaken thing hope it helps you all out
完成的
It is the Ect 1 sensor, [ Engine Cooling Temperature], easy replacement part costs 44 dollars at Bursons. Guarantee you that's what it is. Mechanics don't know $@$*.
完成的
添加一条评论
3个答案
已选择的解决方案
I would start by checking the ignition modual in the distributor. A weak orange spark could also indicate a bad coil. Doesnt sound like a fuel issue . may also want to check the distributor cap , rotor and the coil wire . When checking the coil look for any obvious moisture . Theres no joy with a leaking coil. Hope this helps
这个答案有帮助吗?
得分 3
2条评论:
Hello I have a 2001 Honda CR-V I had it running 5 min and it cut off and won't start back up it tries but it won't start the lights and radio works I thought it was fuel pump but can hear it coming on I was thinking fuel filter could there be someiim missing pls help
完成的
Something I'm missing pls help sorry typo
完成的
添加一条评论
Ok what coil is everyone talking about. I have this same trouble. Taken to 2 different places and neither mechanic can get it to act up for them. Of course, just like a child when sick and you take them to the dr and they feel better day if appointment.
Please help me
这个答案有帮助吗?
得分 0
2条评论:
Ignition coil may be inside the distributor cap, before you spend money on that, buy a spark tester from your parts store, it looks like a spark plug but it does not have the L shaped tip, there are different designs so go with what they carry. Put the spark tester in the end of the spark plug wire, ground it, have a friend try to start the car and see what your spark looks like on the tester, if no spark or intermittent spark, most likely you need an Ignition coil but try all 4 spark plug wires, if one or some seem ok but not all, then do a tune up, cap, rotor, spark plug wires also go bad and have added resistance and can also make weak spark, if all 4 seem weak, and as long as you have the cap and rotor off anyways, change them also, how old are your spark plug wires and plugs, go ahead and do everything for peace of mind and your doing it yourself, disconnect your battery if changing the ignition coil as you might short out its wiring. Do you have a security radio, do you know the code to reset it.
完成的
Having a similar problem, sent distributor for checking
完成的
添加一条评论
I'm actually having similar issues with my 01, changed the fuel pump, fuel filter, both O2 sensors, catalytic converter, cap, rotor, coil, plugs and wires and the pgm-fi relay. Still nothing has helped, no check engine light or
这个答案有帮助吗?
得分 0
2条评论:
Did you try main relay
完成的
Ignition module.? Located under distributor cap with coil
完成的
添加一条评论
添加你的答案
Liz Davenport 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 70
总计 19,875
