跳转到主内容
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
Why does it pull to one side when brakes applied?
The car hase been to several repair shops and everything to do with the brakes have been replaced. Calipers, hoses, rotors, pads, and even one shop replaced the lower arm bushings. No one can figure it out!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
If it's
been in an accident it could be a bent frame, or alignement (photo looks as if passenger side has been dented) it could be the power steering pump has a blocked port or crimped hose.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 1
2条评论:
That's the iFixit photo for the device page, not this person's exact car. Good eye, though.
完成的
Thanks and no its not been wrecked and that photo is not it. Car ran straight and true for years and then it just started the pull. Seems if you jab the brakes it pulls hard at first and then comes out of the pull as the braking is continued. I am leaning toward a bad master cyl or ABS unit maybe.
完成的
添加一条评论
添加你的答案
mark 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 1,032
