跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Touch screen not working after replacement
I have put in 4 diffrent screens and they all do the same thing they turn on look great but touch only half works and works half of the time can someone help what else could it be or what am I doing wrong I don't think that I would get 4 bad screens
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Make sure all the connections to the motherboard are securely in place, there may be times when some of the cables are partly connected and some are not, leading it to not function properly. Also this tends to happen if you tighten the bracket above the cables too tightly not giving the cables a secure fit into the logic board. Also it can be easy to damage the connectors when not being careful, leading the components to breaking or not functioning properly. I always recommend turning off the device and taking out battery before repair, just to be cautious and to help not accidentally fry a component while during operation. It can also occur when people purchase off-brand screens, which tend to be the really cheap priced LCD/digitzer. So make sure you purchased the screen from a reliable company/brand. Hope this helps the situation. If 4 screens are all having a difficult time, it may be the component on the motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
Ok here is what I found out so I got 4 new screens and the screens keep doing the same think touch only work part of the time and if I start over and close the phone and put my password back in it work for a little while so i ordered a new screen already put together with back plate and home bottom front camera and mic. Cause I put that back plate on every screen I got and they all do the same thing so that has to be what is wrong and if not their is one other peice on the logic board that need to be heated up with a heat gun to be replaced so I am hoping that this back plate is the problem let u guys know in a few day when I get the full assembled screen installed
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bobby Cook 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 64
