跳转到主内容
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 个问题 查看全部
Why no power unless charging?
Hi. Can anyone confirm the issue. My Ipod Nano 6th Gen only powers on when connected to the charger. As soon as the charger is unplugged the screen turns off and is unresponsive until the charger is reconnected. My suspicion is a dead battery, but could do with a second opinion.
Many thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Yes sounds like a dead battery, they are usually not that expensive so I would recommend ordering one. Be careful when taking the screen off, it is easy to chip/crack
这个答案有帮助吗?
得分 3
2条评论:
I agree with Reece. Replacing the battery should surely fix your issue. When removing the device from the charger causes it to power off instantly, it is a very strong indication of a failing battery. This applies to many different devices too.
完成的
Excellent. Confirmed my suspicions. Thanks for your help
完成的
添加一条评论
添加你的答案
Bigphilly71 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 3,268
