跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Touchscreen not work - Tested using multiple Displays
Hello,
I have a iPhone 4S, touchscreen stop work after LCD replacement (Broken).
At first i think it may be from new LCD but after test with another one i have same result, no touch...
Sometimes after plug and unplug flex it start working, but after sometime or reboot no longer work. (This happen with a few trys)
Flex and ports are not damaged, pins are normal.
I have try to clean many times without success.
What can be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you are sure the displays you have tried are working, it pretty well narrows it down to board level problems. It could be the digitizer connector on the board or possibly the touch IC. I'm just not sure how far you want to go on a device that old. I'm usually pretty gun shy about going in too deep on those, since you are almost guaranteed to break something while you are in there.
这个答案有帮助吗?
得分 1
3条评论:
I have edited main post with 2 images. I'm sure LCDs works, tested them in other devices and they are OK, i test with 3 different Displays. Looking at ports i think they are good
完成的
ports look good to me too.
I don't know man. It sounds like its probably the IC then. Could be something else but on a device that old...all I can do is guess.
完成的
Yes i understand. The problem is sometimes after several plugs it work and sometime after it don't :(
完成的
添加一条评论
添加你的答案
Tiago 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 80
