跳转到主内容
于2016年3月上市。型号 SM-G930V。
425 个问题 查看全部
Front camera isn't working.
Hello!
My s7 front camera isn't working for quite a long time. its just dark. Dark as in nothing comes up when I turn it on except for option and dark screen.
Once I deleted some apps which I thought is interfering with my camera and it worked. But the next time I rebooted my phone front camera stopped working again. I denied camera permission for all apps just to make sure nothing is interfering, but still it didn't work. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I would try a factory reset to try to get it to work, if this doesn't work it may need to be replaced, in such case I would try to claim under warranty.
完成的
添加一条评论
2个答案
最有帮助的答案
Try other camera apps, such as OpenCamera.
这个答案有帮助吗?
得分 1
添加一条评论
Try a factory set or hard reset.(This will remove your phone data)
Turn off the device.
Press and hold the Volume Up key and the Home key, then press and hold the Power key.
When the device logo screen displays, release only the Power key
When the Android logo displays, release all keys ('Installing system update' will show for about 30 - 60 seconds before showing the Android system recovery menu options).
Press the Volume down key several times key to highlight 'wipe data / factory reset.'
Press Power button to select.
Press the Volume down key until 'Yes -- delete all user data' is highlighted.
Press Power button to select and start the master reset.
When the master reset is complete, 'Reboot system now' is highlighted.
Press the Power key to restart the device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shadman Rakin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,415
