跳转到主内容
The Motorola Droid 2 (A955) is the fifth phone in Verizon's Droid line.
13 个问题 查看全部
问题已关闭
How to replace/fix a power button
I am in the market for a Droid 2 and I have found that is in prefect working order minus the power button. It will not turn the device on. The device has to plugged in to power on and then it works fine. All of the apps and features are good to go then. Any advise
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If the physical connector on the frame is not damaged, then find another power button. If it is damaged, replace the frame (this will require much more work, and you should look at the guides for removing the LCD and digitizer). A droid 1 frame should work and you can get one cheap from a water damaged phone.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 6,096
