跳转到主内容
panic(cpu 1 caller 0xffffff8000a7b028b)
Hi, i google this panic error line, and keeps popping up, i replaced the HDD, and i get the folder missing icon with another macbook pro that i have, but when i try to boot again with the same HDD i get this error line.
heres a picture of the error
but its not the OS, i set that HDD in another macbook pro 13" 2010 and its good i can log in with no problem
heres my toughts:
the flex cable of the hard drive must be replaced, or the logic board must be replaced, but im not sure
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
"panic cpu 1 caller" Unfortunately your cpu or another they of chip is failing. Replacement of your logic board is probably your best option.
这个答案有帮助吗?
得分 0
2条评论:
So the cpu 1 it's related to logic board failures?
完成的
i have the same problem went to install a different hard drive give me the same picture but if i used the hard drive that comes with the computer don't happen so the cpu is ok
完成的
添加一条评论
添加你的答案
armandomh91 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,124
