跳转到主内容
加入维修社区 - 创建账户
The Syma X5C is a four-channel quadcopter with a built-in camera.
drone Won't take off!
When my Syma is all paired up to to the controller and its ready to fly it won't take off. I've had a look and realized that the rotors are reversed and push the quad copter down. i have tried everything i know of such as calibrating the drone. i have no clue of how to continue , could someone please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
There are 2 motors that turn clockwise and 2 that turn counterclockwise. The props are also different and each is marked to go on their matching motor. On each arm of your drone there is either an A or B and on the props 2 have an A and 2 have a B. Make sure that the props are on their proper motor.
I don't feel calibration is your issue but.....to recalibrate the gyro: After you bind your Tx and drone with the up/down throttle sequence(and have solid lights), move both Tx sticks to bottom right. The gyro will recalibrate after a second or 2 and the lights will flash then return to solid.
I hope this helps and you are flying again soon if not already.
这个答案有帮助吗?
得分 0
1条评论:
My drone won't fly ! Battery's are charged seem to be the connection from battery to drone! any suggestions ??
完成的
添加一条评论
One of my B wings will not move what should I do?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Billy Frank 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 17
总计 5,612
