跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Why is iPhone 4 heating up after screen replacement?
I replace iPhone 4G LCD Touch Digitizer Screen and also the phone had some water damage. I took it apart and place all parts in tupperware with rice for 48 hours. After assembling it together it turn on and all functions work but from camera and my concern is the top right side of the phone is heating up a lot it is around the power button and back camera i have no idea where is it coming from. I try to replace the batter and still the same. I also look check the lower antenna connector to make sure is connected right. Any advice?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
What is tapeware?
完成的
sorry bushing i meant to say "tupperware with rice" i fix my post. :-)
完成的
添加一条评论
2个答案
最有帮助的答案
since you had water in it. there is most likely an accumulation of corrosion at some of the connectors on the board. chech for the discoloration on any of the gold colored connectors on the board. once you find it. clean it with alcohol. but very carefully!
这个答案有帮助吗?
得分 1
添加一条评论
I had a phone come in the other day that was getting extremely hot and killing batteries. I found that the whoever changed the screen did not properly seat the rear camera and the camera was fire hot. I could not touch it. I removed the camera and cleaned the connector and reassembled the camera and the rest of the phone and it did not heat up again after that. I would also check the dock connector connection to the mainboard depending on where the heat is coming from.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
info 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 6,868
