跳转到主内容
The Dodge Dakota (called the Ram Dakota for its final two years of production) is a mid-size pickup truck from Chrysler’s Ram division (formerly called the Dodge Truck division). The second-generation Dakota began development in 1991, though they were not introduced until 1996 for the 1997 model year.
71 个问题 查看全部
问题已关闭
How will you know when to replace out the intake manifold gaskets
2001 dodge dakota pick up will not stay running . engine starts but stops immediately. engine had over
heated. bad radiator. Put pick up on diagnostic. Had to replace out the , injector (all)
Throttie sensor, intake air temp. sensor, Engine coolant temp. sensor,the MAP sensor,
ldle Air control valve. spark plug, All the lgnition coil. And the Radiator. Put it back on the diagnostic, all good no more trouble codes. Even check all the vacuum hoses. But
it will not stay running. WHAT DID I MISS ? ? ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It was the fuel pump on my 2003 Dodge Dakota club Cab. Turn key to on position the fuel pressure jumps to 50 psi. Then dropping to 0 psi in 4 seconds.it should drop to 30 psi. No less. Stay at 50 psi while running.
这个答案有帮助吗?
得分 0
添加一条评论
could be the fuel pump, but it would be a coincidence. It could be air leaks. It could be incorrect connection on the sensors you replaced or a bad sensor. Recheck all your work for vacuum air leaks and sensor connection. Is it giving you any codes?
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 70
