跳转到主内容
Repair guides for Android cell phones manufactured by ALCATEL.
Why can't I delete any media file from memory card?
If I want to delete from SD card it says I have no permission to. Or an error occurred
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Can you please list the steps you are taking when you try to delete?
完成的
添加一条评论
2个答案
已选择的解决方案
@busisiwe , Bus, check out the links below to see if they can help in deleting the media file on your Onetouch to get around the no permissions. Good luck.
https://www.youtube.com/watch?v=bcW3QoM-...
https://www.youtube.com/watch?v=Xc4JZ_Ca...
这个答案有帮助吗?
得分 1
添加一条评论
Probably your SD card has got corrupt. Sometimes, an SD card behaves like a locked card, even if technically it is not. Then you need to remove the write-protection switch. You can visit this link if that is the case for further details: http://www.retrievephotos.com/article/fi...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Busisiwe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 436
