跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Boot loop and keeps turning on
Hello,
Yesterday I asked a question on ifixit, read that first.
Okay, so now, it won't turn off. Even when the battery died, it showed the plug in to charger screen over and over and over again until the battery really died. Now it is completely no power, but haven't tried charging it yet tho. Other than that it works. Haven't restored it yet, I get error 4013 on 2 different pcs. halp plz
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Update: the phone works again. Showing the restore screen and is charging. Maybe a shorted cap between the power button line and ground?
完成的
添加一条评论
1个答案
This is why I run away from water damaged phones. The problem is that you fix one thing and then a new problem pops up. You can keep repeating the process over and over.
Its safe to assume the logic board has suffered severe damage. For sure on the charging system but it sounds like the touch system as well.
At some point you have to know when to stop. That's a decision that you make and only you. But your next step is going to involve replacing ICs if you do continue. And again...I promise that won't be the end of the repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gigabit87898 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 80
