跳转到主内容
加入维修社区 - 创建账户
My tablet can't pwer on
I have problem about huawei tablet
it's can't power on.
I checked the connector and the battery, no problem
what is the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 22
16条评论
where to buy an extra board power ic ?
完成的
it's can't read the puce
完成的
My Huawei t7 cannot power on. I have also press the reset button (volume up+power), but it's not responding. Can I solve it with PC?
完成的
my huawei t3 7 can power on but the screen is blank what should i do?
完成的
It ask me for a code.
完成的
显示更多的11条评论
添加一条评论
1个答案
已选择的解决方案
@mohamedeln , med, Found this info. from searching through forums with similar issue as your huawei tablet t1. Hard reset. Take your sim card and memory card from the tab before the reset, battery is fully charged. Personal data from the tab, contacts, pictures, messages, apps. etc., will be deleted if it was not backed up.
Press and hold volume down key and power key for a while, your screen should turn on with option to enter recovery, follow the prompts to enter recovery mode and set the device to factory defaults. Check the link below for tutoral on reset. Good luck.
https://www.youtube.com/watch?v=7zbLOEN0...
这个答案有帮助吗?
得分 14
8条评论:
My phone doesn't have any network
完成的
My tablet says that it still needs more charging, even though it doesnt
完成的
How am I supposed to hard reset it if my screen is still black
完成的
my photos are not saved in sd card they are saved in tablet, i don't want to delete those
完成的
i try all of the ways but nothing works please help me
完成的
显示更多的3条评论
添加一条评论
添加你的答案
med 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 50
总计 47,306
