跳转到主内容
The Toshiba Satellite E45-B4100 laptop was put to market on March 4th, 2015. It has a 14 inch screen and weighs 6.8 pounds. The model number is PSPNAU-001002.
Why won't my laptop charge?
My laptop isn’t charging and is not registering the power source. What do I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Plug in the AC Adapter to the laptop and check display for indication that the laptop is charging. Ensure the output value of the adapter matches the input value of the laptop. Ensure adapter works in separate test by charging a different Toshiba E45-B4100, or a different compatible electronic item.
Turn the laptop off, unplug, and remove the battery for twenty seconds. Now plug in the charger to the laptop from a working power outlet. Check to ensure the green power icon is lit and allow the laptop to charge overnight.
If the laptop still fails to hold a charge then you will need to replace the battery. Instructions on how to order a new battery are available at: https://support.toshiba.com/support/serv...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Delaney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 2,850
