跳转到主内容
Waterproof digital camera released in 2014. The Olympus Tough TG-3 is a Wi-Fi capable, compact camera.
9 个问题 查看全部
How do I connect my Olympus Tough TG-3 to Wi-Fi?
I am unable to connect my Olympus Tough TG-3 to Wi-Fi.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Transfer from Camera to PC by Wifi apparently not. Put camera SD card to PC slot. Yes. Needed this workround since my favorite lap top USB ports got broken. All the USB ports are broken.
完成的
添加一条评论
1个答案
最有帮助的答案
You will need a smartphone in order to connect to Wi-Fi. Download and start the OI.share app on your smartphone. Press and hold the "MENU" button. ( When [Connection Settings] is set to [Off], [Wi-Fi Start] is not available). Select among "Private" or "One-Time" connection and press "OK".
这个答案有帮助吗?
得分 1
2条评论:
Thanks. Press Menu button and choose something from menus - yes, i expected that.
Press and hold - well, thats a point :-) i didnt expected that...
Thank you very much!
完成的
neither did I after a few hours of mucking around, and reading 20 posts that I had to press a button on my none touch screen.
Thankyou
完成的
添加一条评论
添加你的答案
Aaron Lipp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 5,094
