跳转到主内容
加入维修社区 - 创建账户
The Hott T725-8G is a 7-inch Dual Core 5-point touch screen Android tablet.
Why isn't my HottT725 charging?
I have tried charging my tablet using a couple different power outlets with still no charge. I'm not sure if it's the power adapter or the tablet itself. Any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Student Question
完成的
添加一条评论
1个答案
已选择的解决方案
If the device isn't holding a charge there might be a multitude of problems with it. There might be dirt in the power jack. If there is dust or dirt make sure to use pressurized air to blow the dust out of the jack. The power check might be loose or not fit correctly. Make sure the power jack is fit snugly. If it doesn't you might consider replacing the power adapter. It also may be a problem with the battery. Make sure the light to the adaptor is on. If the tablet powers on while it is charging the the battery is faulty. In this case you must replace the battery. A third issue might be there are too many apps or processes running. This could use more charge meaning the battery wont charge. Make sure you shut down the apps to allow the tablet to charge.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emma Carroll 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 350
