跳转到主内容
加入维修社区 - 创建账户
由 Google 和 Samsung 为 Nexus 产品线共同打造的 10 英寸平板电脑。
optimizing apps at startup
When starting up it begins optimizing apps and never quite finishes. After repeating this several times over a few days, it now begins the same way but in a short time it blinks and then goes dark.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I found a solution that need no flashing.My s6 edge plus behaved same way.I left like that because I did not want to lose some applications. On the third day it booted normal.
由完成的 分享
添加一条评论
4个答案
已选择的解决方案
This could be a memory glitch . Holding a bad boot in the memory and booting off the same boot cycle. open the tablet and disconnect the battery then reconnect and reassemble and reboot . This video will help you disassemble the tablet the battery removal is not necessary just disconnect the battery and reconnect .Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
If you have Zedge, this is what is causing it.
I had also done other updates and thought it was Android System WebView as it started right after that had updated. Then I read it's Zedge and I've had that program for almost 2 years. I had restarted phone and was again stuck on "Optimizing", but for me each time it has been a good 20 minutes.
I uninstalled Zedge and it started right up, no Optimizing. Thanks for everyone who figured this out!
这个答案有帮助吗?
得分 4
8条评论:
OMG thank you soooo much! It worked and I didn't lose my ring tones! I guess when I'm ready to change them I'll just reinstall then uninstall when I'm finished
由完成的 分享
Yes, Zedge is the culprit, just uninstall, reboot and you are good to go.
由完成的 分享
Worked! Thanks
由完成的 分享
Genius once I uninstalled Zedge the optimizing 1 of 1 was gone this really worked thanks a bunch
由完成的 分享
I uninstalled Zedge and the phone still goes into Android starting 1 of 1
由完成的 分享
显示更多的3条评论
添加一条评论
I disconnected the battery, then recharged completely. The nexus started back up like it should. However, the screen does not respond to touch. Yikes! I must have messed something up.
Any advice?
这个答案有帮助吗?
得分 0
添加一条评论
I know this is a long time ago,but…
Ensure that the ribbon cables you disconnected to replace the battery are fully and properly reinserted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Lovin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 42
总计 17,171
