跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why is only one "wet indikator" red
I just fixes an iPhone 5s which wasn' charging and didn't respons to DFU reset. Turns out, a new battery did the trick.
But here is whist pusseled me: The guy who sold it swore that it wasn't water damaged,
The water indikator by the ear speaker and sim tray was bright white, but the one by the battery was red. Seems impossible.
Can anyone explain?
Bjop
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It is possible, water didn't go all the way trough the iPhone...often situation in servicing business. If everything else is ok, don't bother, carry on with usage...
这个答案有帮助吗?
得分 0
1条评论:
But weird though, water in the middel of the phone. I was thinking condensed water maybe.
Anyway, looks ok. Screen looks great, god response and finger print Trads perfekt. Ill run it for a couple of days to see if battery drains.
Thx
完成的
添加一条评论
最有帮助的答案
It is most likely not water damage to the entire logic board. Probably a small amount of water from rain, or another source got into the phone. Since the water damage indicator near the battery was red, the water probably got into battery connector. This would short the pins in the connector causing rapid power cycling ultimately killing the battery. Even though replacing the battery, in this case, would fix the problem, I would recommend inspecting the logic board for any other corrosion before continuing use. Doing this will ensure you don't have any issues further down the road.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bjorn Stokke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 72
