跳转到主内容
Released in 2011, the Asus K53E-BBR7 laptop features an internal 640GB HDD with a speed of 5400 RPM, and a 2nd generation Intel Core i3 processor.
5 个问题 查看全部
Why won’t my laptop charge when I have it plugged in?
I noticed that when I connect my power adaptor to my laptop, it won’t charge. I’ve noticed that there is heat coming from the connector head of the power adaptor, but it still isn’t charging when it is connected to my laptop.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you are noticing that your power adapter is functioning but your laptop is failing to charge, there may be an issue with your laptop’s charging port. The charging port often fails on this laptop due to excessive use. Refer to the Asus K53E-BBR7 troubleshooting page for additional information at Asus K53E-BBR7 Troubleshooting.
这个答案有帮助吗?
得分 1
2条评论:
yeah and check if the battery is given reacharge by the mainbord
完成的
but most laptops have a split funkion that reacharges the battery and the cable power the pc itself and leave the battery to charge alone if it cant even turn on the adapter may not have power at all
完成的
添加一条评论
添加你的答案
Christina Nelson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 202
