跳转到主内容
The Acer Iconia Tab 8 A1-840 is an 8" Android wi-fi tablet with 16GB of flash memory and 2GB of RAM. Acer released the Iconia Tab 8 A1-840 in 2014.
Why won't my device charge?
I have plugged the charger into the device and into the outlet but it won't charge.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I have the same problem.. I didnt notice it was drained that night but i charge it for 6 hrs but theres no light that shows its charging.. And the tab and its charger is so cold not hot .
完成的
添加一条评论
1个答案
已选择的解决方案
There might be several reasons the device is not charging. The charger or the USB might be defective. In order to fix the problem, plug the charger into a different adapter. If this does not solve the issue, check to see if the USB port is damaged. Replace the USB port if it is broken. For more information, please refer to the troubleshooting page.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 6,655
