跳转到主内容
The HP Compaq 2510p has a part number GM651AW and was released June 2007. It features an Intel Core 2 Duo ULV processor and 12.1 inch display.
4 个问题 查看全部
Keyboard keys not responding when pressed.
Often when I press certain keys on my keyboard, the computer doesn't doesn't respond.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
iFixit Technical Writing Project student
完成的
添加一条评论
2个答案
You could have dust under the keys. Use some compressed are and spray underneath each key.
这个答案有帮助吗?
得分 0
添加一条评论
Have you taken your computer apart one time or another? if so it might be the connector underneath your keyboard that connect to the computer's motherboard that either is loose or bad connection :) Good luck! hope it works out!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nathan Pereira 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 152
