跳转到主内容
The HP Compaq 2510p, model number "GM651AW" and was released June 2007. It features an Intel Core 2 Duo ULV processor and 12.1 inch display.
4 个问题 查看全部
My laptop won't power on.
I press my power button, and my computer wont turn on. There's no lights when the battery is plugged in either. Does anyone know whats wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Student question
完成的
添加一条评论
2个答案
已选择的解决方案
You can try doing a static discharge . Remove the battery and unplug the laptop so there is no power to it at all . Then hold the power button down for 60 seconds this drains any residual power from the memory and allows a clean boot. Then reconnect the battery and power and boot the computer normally. If this gives no Joy test your power adapter to see if there is an issue there .If the adapters not providing power it wont charge the battery Hope this helps
这个答案有帮助吗?
得分 4
添加一条评论
Your battery may be defective. However try removing the battery for 60 seconds and see if the problem persists.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan Champagne 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 2,457
