Why is my battery not lasting the time expected?
The battery to my Hisense Sero 7 is not holding the full charge and lasting less time than the battery life should hold.
The reason for the battery not lasting the amount expected is because the battery is faulty or other charging components arent working properly. Other problems that can also cause this include having dust inside your vents which can be fixed by cleaning out the vents and cause the fans to work properly. Another problem that should be revised before changing your battery should be to try and change the charging ports and wall ports to make sure those charging options arent the problem. The battery over time loses its charging capabilities and causes battery to work harder and in result start to overheat. We suggest replacing the battery if these are not solutions.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 197
