The Canon EOS Rebel T5, also known as the EOS 1200D, is an 18MP DSLR camera released in February 2014.
May @mayanded
声誉积分: 1
发帖于: 2016年11月8日
Card is formatted and empty. Can take only 3 pictures before it says card is full. How do I delete internal memory?
这是一个好问题吗?
3条评论:
Hi,
What capacity is the external SD Card that you are using?
Have you tried using a different SD card to check if yours is faulty.
Did you format the SD card in the camera?
由 jayeff 完成的 2016年11月9日
Capacity is 32. Yes, I tried different SD cards. Yes, I did format the SD card in the camera. Still same problem.
由 May 完成的 2016年11月10日
Hi, Have you tried to manually reset 'File Numbering' in the settings area. Just a thought.
由 jayeff 完成的 2016年11月10日
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 582
Hi,
由 jayeff 完成的
由 May 完成的
由 jayeff 完成的
