跳转到主内容
The G3 Controller is gamestop's version of a gamecube controller, equipped with A, X, Y, Z, B, Turbo Button, joystick, C-stick, left and right triggers, and a directional pad.
Why is my controller moving the character when I am not
My controller causes my character to move when I do not move the control stick. Is it dirty or is it just a bad signal?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Turns out there was an error when the console recognized the controller so I just unplugged it and re-connected it to the console.
完成的
添加一条评论
3个答案
最有帮助的答案
Often times, disconnecting the controller and blowing into the connection port on both the controller and console can fix this problem.
这个答案有帮助吗?
得分 1
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
It may be dirty or your joystick may be misaligned. I recommend you check out our joystick replacement guide, and use the steps to clean out the area and then reattach your joystick. If the problem still persists it may be a problem with your motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Gonsalves 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 512
