跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Touch ID not working after screen replacement (original Home Button)
Hello, yesterday I changed the display on an iPhone 6, everything was working fine except for Touch ID. As I already repaired many iPhones I know that only the original homebutton will work with touch ID so I used the original button, but everytime I try to register a fingerprint it says "Touch ID failed" (don't know the correct translation as my phone is in german). Pressing the button to get to the homescreen and so on works fine, just touch ID is giving me problems. I did definetly not damage any part of the flex cable or the button.
I already tried performing a factory reset and also restarted with home and power button but still no success, also reattaching and cleaning the ports with isopropanol didn't fix it.
Does someone have an idea what else I could try?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try another home button extension cable. You can buy either the cable only by itself if you want to install it on the metal plate or buy one with the metal plate and home button extension cable pre-installed as one piece.
If that still does not work then I'm afraid the touchID for the home button has gone bad.
A link to the part on the iFixit website in case you want to buy one from here:
iPhone 6 LCD Shield Plate with Sticker and Home Cable
Note: Replacing the home button extension cable will not cause the TouchID to not work properly.
iPhone 6 LCD Shield Plate with Sticker and Home Cable图片
产品
这个答案有帮助吗?
得分 3
4条评论:
already tried that, forgot to mention it... I used the flex cable from another iphone where touch id works but it doesn't work...
完成的
Did you transfer the small metal plate under the touch ic flex (adhered to screen) to new screen? It's right under the home connector flex connection in picture below. I would also check to see if the connector itself has been damaged....as in any pins damaged on the original home button itself (microscope needed).
https://www.google.com/search?q=iphone+6...
完成的
Sorry for the late reply, yes I also transferred the metal plate to the new screen. The connector isn't damaged but I am beginning to think that the person who sold me the phone is lying about the home button (told me that the phone has never been repaired before)
完成的
Yeah, it could be that the home button was replaced before. When I sell phones that been repaired before I usually say they have been refurbished and restored to working condition but touch ID no work or just say touch ID won't work. Either way is acceptable I believe.
完成的
添加一条评论
bro just reset settings that works
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ppalfinger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 954
