跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6s Camera Not Working. Missing resistors?
Hi guys, I recently dropped my 6s with a case on, and now both cameras and flash aren't working. I opened it up for inspection and noticed that there are multiple pads without a resistor on top of them. It is C5313_RF and C5314_RF. Is it possible to jump these? I'm fairly competent with a soldering iron and will buy a micro tip if needed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
For anyone that happen to have the same problem, replacing the camera with a known working one fixed the issue.
这个答案有帮助吗?
得分 0
2条评论:
Glad to hear that this solves the problem, however I'm curious does it solve the issue with the front camera as well as the flash?
完成的
Yeah it solved all of my issues.
完成的
添加一条评论
最有帮助的答案
First, check in the schematic to make sure they are definitely not "no stuff" components, where nothing is supposed to be located.
Don't jump them, just find out the value of these and order them from farnell/mouser/digikey, or remove the same value component from another dead board (if you have one about)
这个答案有帮助吗?
得分 1
4条评论:
Thanks for the help. Thats what I'm here for, to find out if these are supposed to be blank, and if they have any control of the camera power supply.
完成的
The problem is that Apple has really good lawyers who love to hassle websites that post Apple schematics.
Google "iphone 6s schematic" and you will find the schematic. Looks like 5313 and 5314 are both 22pf, 5%, 50V.
But If I'm reading it right, and lord knows I mess up, it looks like 5313 and 5314 are for the NFC system.
完成的
Well if it's for the NFC system, I shouldn't worry too much about it. Hopefully it doesn't control the camera
完成的
NTC is the thermistor line for the thermal contact pad. in this case the camera. do not confuse NC non contact for NTC thermistor temperature control. caps are there to store energy. high value 10uf will enable a demand storage. lower values in the picofarad range stabilize a voltage jumping to ground will only reduce resistance causing failure
完成的
添加一条评论
There is "no stuff" on those http://imgur.com/a/vJWud. Is camera just blank and frezzes when you switch between them, or it switches normally just both are blank?
Also those are suppose to be capacitors, would not be a good idea to jump them, you will create a short
这个答案有帮助吗?
得分 1
3条评论:
Thank you for the photo. The cameras are both just a black screen, and the flash doesn't even respond. I don't even really know if it switches, but the app doesn't freeze at all
完成的
Usually if one camera doesnt work neither will in camera app. Try use facetime app and see if the front camera is working.
完成的
Confirmed not working with FaceTime app. Just shows my background when I make a call
完成的
添加一条评论
添加你的答案
Kyle C 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 2,624
