跳转到主内容
The Sony Ericsson Xperia X10 Mini E10i runs on a custom version of Android and features 3G access. Released in 2010.
33 个问题 查看全部
Wife drop it on the toilette.
Hi there,
I'm from Brazil and new here.
As I said my wife did that! She says it felt from her back pocket into water. She take it back in the same time, so I figure that it stayed in water for about 3 seconds...
The battery was almost empty but when she take it back the phone had turned off. She dryed and tryed turn it on again. Don't worked. As she where shopping, she just tougth the battery went off and keep shopping!!!
Resuming, the phone stayed like that for about 6 hours.
When I tryed to turned on, didn't worked so I plugged on and started to recharge the battery. Didn't worked. Well, the battery don't pop off like other phones I had, so I search and foud this: Sony Ericsson Xperia X10 Mini E10i Teardown
Thanks iFixit!!!
In about 5 min. I managed to unplug the battery, but couldn't make to pop off from it's container, it looks like glued or some. It still there, but unpluged.
Using an air brush, gently I dryed the phone, I was happy 'couse it wasn't wet, only litlle tiny drops here and there, all outside the eletronics. Re-assemble and start to charging again. Still dead.
Now the phone is inside a jar of rice like I read in many places in the hope it dry some moisture that I coldn't see. I'll let there for three days.
Someone knows what coud happened? Did I loose the phone? It's the battery only? I'm sad.
See here:
http://forum.xda-developers.com/showthre...
So much worse and the guy succeed, his phone became a fish, my wife's just took a chower...
Please help!
Eric Vieira.
Sorry if I write some. wrong.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Dear Eric,
I repaired already 3 phones with DESTILLED WATER (the pure water without any minerals.
Take battery out andp ut the phone in for a while to rinse it. Then dry in which way ever.
The last mobile I "repaired" in this way was a Nokia Xpress 5800....
Best Regards
Otto
这个答案有帮助吗?
得分 1
添加一条评论
let your phone sleep in rice for the night - take out battery sim card sd card and strip it as much as possible. open up the keyboard if it has one and immerse in dry rice
the next morning my wife's phone was back to normal
if you can leave for a couple of days to make sure! our screen still a little bit misty :) but the phone works after being dropped in the bath!
这个答案有帮助吗?
得分 1
添加一条评论
Hi Mónica!
Since ur from Portugal, let's speak Portuguese.
A SE disse que ficaria R$850,00 para arrumar. Como paguei R$900,00, não compensa. Guardei o telefone e assim que a placa-mãe baixar de preço, vou comprar/importar e arrumar eu mesmo.
Agora, aqui no Brasil esses eletrônicos são muito caros, aí em Portugal deve ser mais barato, apesar do Euro.
Boa sorte!
Eric. de M. Vieira.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric de Mattos Vieira 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 5,402
