跳转到主内容
加入维修社区 - 创建账户
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Power Flex Cable Replacement Issue
So i seen the power flex on this ipad was bad, could see there was a tear. So i replaced with another and of course the adhesive on it is terrible nothing wanted to stick in place. So i used a bit of super glue. Now Iam not sure if this caused an issue or not. When i first got it all connected and in place, I tested Boom Ipad comes on No problem. Seal it all up. Nothing will not power on via the power button. Connected it to the power cord, comes up. I removed the power flex again and looked at the cable it does not look "damage" But i am wondering if the super glue could have damanged the flex?
Something else i can try?
Any suggestions are helpful
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would order another power flex cable. Its clear that the cable is damaged if it is no longer working and power on when plugged in. Very easy thing to do while replacing the screens on these.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mikebarkas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 135
